XT1 question regarding bagger and trailer cart
wpamike
Is there any way to attach a 10 cubic ft trailer cart to a Cub Cadet XT1 without having to remove the bagger assembly?
Snowman1967
I took a 12" X 4" 1/8" thick piece of weldable steel plate, drilled a hole in it for the bagger assembly pin, and a hole for the hitch pin, then spot welded it onto the bagger assembly. This allows me to hitch the trailer to the mower without removing the bagger.
wpamike
Thanks, Snowman. I'll look into that.
