Flyfisher1
- Sep 27, 2017
- 1
- 2
Help......My machine is only two years old. Runs perfect & all was operating as it should. This just started, while running & trying to engage the pto for the deck, it will stall out, regardless of the engine speed. Have fresh fuel, new fuel filter, spark plugs, set the coil gaps & sprayed a cleaner in the carb. Everything appears to be in place on the deck. Tractor is always clean and stored in a garage. Any ideas out there would be much appreciated.
