I got quite a deal on an X500. The hour meter showed 21 hours, and I know that's not right. Engine seems to be in great shape, and the oil stays clean. The hood and floor pan still look like near new. The transmission is another story. The oil looked black as soot. I doubt that it has ever been changed. The reservoir was the nastiest I have ever seen. It was covered with crud. I had planned on putting a transmission in it, but I serviced the engine and trans and have run it for 9 hours. Transmission works perfectly, but coasts just a short distance when you take your foot off the pedal going forward. I have heard there is an adjustment screw under the pedals that should take care of that. Since it is doing so well after being serviced, do you think it might still go the distance or close to it?
Thanks in advance.
