Neighbor said her x475 kind of back fired and shut off. I towed it up to my garage, it has sparked, I spray starting fluid into the carb and it will not fire. It does pop/back fire while turning over. Any help/suggestions are appreciated. Tha ks
Yes that's what I'm thinking as well. I took the spark plugs out and dumped a little gas in and it still would not fire.Sounds like a timing issue.
