Export thread
x475 No Power...need help
#1
O
Offroad
The wife was mowing and my x475 just died, Thought it was out of gas but when i put the key in it i get nothing? So i put the battery charger on it and still nothing (no lights come on the dash). Can the battery go dead that fast?
#2
B
Buckshot721
Did you have the battery checked? Are the connections clean and tight? Did you check the safety switches?
#3
M
mullins87
I never had that happen to me, until last month. I had two batteries on two JD's go bad almost as if you had cut the cables or flipped a switch. Interestingly enough, the batteries were built in March and April of 2009.
#4
O
Offroad
Thanks buckshot721 and mullins87, I will check on these things
