X390 Hydraulic Deck lift problem
nortonbyk
The deck lift/drop hydraulic control lever on the left side of the dash is locked up. I bought this machine new in 2018 and has worked as it should since then. I parked it overnight after mowing part of the property. Next day, the lever is locked in place. I traced the control rod(s) and I can't find a jam. Is there something I inadvertently did to lock it out? I really don't want to take it to the dealer if its a simple repair. Thanks.
