X320 Won't start
dougcoutts10
I have an X320 John Deere that won't start. So far have replaced the solenoid and checked the seat and brake safety switches (Both have continuity) and after testing replaced the battery. When I turn the key I get absolutely nothing. Hours display doesn't light up, no clicks, nothing at all. Ideas?
winmod21
I'm not one qualified to give advice, but until the pro's post their advice here, which I'm sure will help get you going, in the interim, I'll just mention that I have read similar threads of similar issues, and as I recall, it was typically either the fuse for the ignition switch and/or for the ignition harness wiring, or the ignition switch itself. Did you check your fuses? And you might do a search -- in the search feature above -- for testing your ignition switch. Hope that might be of some help.
dougcoutts10
Forgot to mention the fuses, did check all fuses seem to be good. Tested for continuity on the wiring harness and have continuity to the ignition switch. Was thinking ignition switch may be bad.
