vestaviascott
- Jul 2, 2016
- 3
- 13
My JD X320 has an issue where when I raise the deck, the parking break moves as if the two were connected. Apparently, the rockshaft is moving whenever I press the deck lift OR the parking break. I don't believe both of these pedals should move the rockshaft should they?
Anyway, what this is causing is that the deck lift is acting like a break and engaging the same cam that the parking brake engages to prevent the Go pedal from operating.
Can someone clarify for me, should the deck lift operate independently of the brake pedal or are they designed to work together as one?
Also, the parking break doesn't appear to fully reset to home position, I can still pull it up with my hand. Perhaps a weak or worn spring?
