X300 Stalls
gr8t73
'I know this is a common problem with the X300 and I've read many online postings regarding this but never saw a solution. My X300 starts and runs perfect for 15 or 20 seconds then stalls. If I leave it at idle it will run a bit longer but still eventually stalls. I've changed the fuel filter, tested the engine control module, tested the fuel pump and checked all the fuel lines to ensure they were clean and clear. I was hoping someone on this forum might have the solution.
