X300 John Deer
Farm Bob
Will not start unless you by-pass the selonoid, Ignition switch ohms out as good, have replaced selonid twice. Still will not crank without by-passing selonoid
Scrubcadet10
Moderator
Staff member
Check your voltage on the trigger wire of the solenoid in the start position.... does it have a separate starter and solenoid or is the solenoid piggy backed on the starter?
when you turn the key, does it make a click noise?
Farm Bob
It does have a separate solenoid, not piggy backed. Makes a very faint noise when turning the switch to on but nothing when turning all the way to crank. JD X300 with I believe a 17 hp kawasaki , mower not on site
Scrubcadet10
Moderator
Staff member
It could be a safety switch... you'd hear it click when the key is in start, i think the faint click you hear is probably the fuel solenoid on the carburetor.
Farm Bob
I have already by-passed the seat saftey switch, what else should I try?
Scrubcadet10
Moderator
Staff member
Could you post the serial number, not model, but serial number of the tractor, all i'm finding on the X300 is a starter with the solenoid piggy backed on it.
bkeller500
Brake peddle switch suspect????????? PTO switch is OFF?????? Battery suspect??????
