I have owned an X300 for 8 years. I recently replaced the deck belt and noticed that the belt comes alarmingly close to the bolt on the right hand side that adjusts the rear of the deck.Called my dealer-said to use deck leveling kit to check height. Did that-had to lower both raer bolts and now the belt is even CLOSER to the bolt coming off the rear draft arms. Also noticed that my height adjust knob only goes down to about 2 on the scale, any ideas? Never had this issue before. Thanks for your help!
