anytimemower
- Jan 16, 2017
- 1
- 3
Hi to all and ty in advance for any and all that can help
well were do i start was doing service on x300 found out battery was dead and the carburator had some issues with build up so i cleaned carburator and charged the battery with 4 ohm load from a professional charge system so when i was finished with the unit started to pack up when i was ready to finished testing unit for driveability had to shut it off to move it out of basement when i went to go start the unit would not start had no power to the hour meter and was at loss checked the fuses and the key switch checked everything with power probe also checked all of the wires coming off the key and the switch itself but still no start i thought it might be the ecu i didnt want to go buy one until i was sure -with the cost an no return policybut once again every one i called said that it was not the issue i had called a few of the dealers in the area but no one could seem to figure out what could be the problem now im here awaiting answers or any advice.
