D2hornets58
- Mar 4, 2012
- 25
- 288
I have a 36 inch wright velke walk behind mower with a sulky. It is a gear driven mower. I just replaced the two wheel drive belts on the sides and also the drive belt on the bottom. Whatever gear im in it will go to the right. Ive tried adjusting the brakes on both sides but it hasnt changed. It seems like the right side moves slower because if i pull the left brake to turn left it turns much slower then it does if i pull the right brake to turn right. I can get it to go striaght by pulling in the left brake a little but that slows down the mower. If I am going up a hill it cant make it unless i dont touch the left brake. Im not really sure what the problem could be. Any ideas?
