Won't do anything when I turn the key on; has a new solenoid on it already.
James Slater
  • / Won't do anything when I turn the key on; has a new solenoid on it already.
After mowing, I washed the mower with a hose and now it won't do anything; nothing when i turn the key on, blade deck won't move. Can anyone tell me what to do to fix my
ZTS 7500 Craftsman zero turn mower. THank You
SeniorCitizen
Allow it to dry a day or two then squirt WD-40 into each safety switch and operate them a few times. Also any electrical part that may have gotten water in it and ignition switch. The next time you have the uncontrollable:laughing: urge to clean it, vacuum it off so debris isn't forced into nooks and crannies and then wipe the parts down with a damp cloth that need to be show room clean.
James Slater
Having a problem find the safety switch; my manual does not clearly show it on the wiring diagram. HELP:laughing:
SeniorCitizen
I'm certain there is more than one safety switch but I can't help you with their locations.
