Wizard Plus 16hp
FTS902
I have a wizard plus with a 16hp Brigs and stratton vanguard V-twin. I intend to use the motor for a different application.
Because it will be on a different vehicle, I need to remove some or all of the safety sensors (one for brake, one for seat, and one for mower) but I'm not the best at wiring.
I did however spend some time today to draw up a schematic of the entire system. If someone could look at it, and give me some tips as to bypassing these features I would be very gracious.
I only need the bare minimum, and I'd like to replace the ignition system with a on/off switch and push button start only. nothing else.
