aka rotten
- Mar 21, 2012
- 20
- 44
First of all i,m no expert in the wiring of these therefor i come to you experts.Series 8 older mower that ive re worked everything that needed doing underneth.Orginal engine was 12 hp briggs electric start.Engine was blowen when i got it and i just replaced withTecumseth 10 hp.reason beng i had what is a barely used one here.Problem is i went from electric start briggs engine to electric start tecumseth,difference i see is plug to starter is different.Using esisting wirining harness can any of you experts tell me what i can do to make harness in there work?This mower is mine so i dont mind having to cut and splice a wire if i can make it work.Only problem again i can see is starter hookup.Thanks in advance for any help.
