Wiring schematic needed
heavy_kevie
I have a 2008 Simplicity Citation (2690444) B&S 49T877-0025-G1 (Replacement engine) and was mowing for about 40 minutes when the blades stopped turning. Replaced the 20 amp fuse for the PTO which had blown but the blades do not turn when the PTO is engaged. Have not voltage to the PTO connector at the clutch, have 12v on an orange wire to the PTO switch, all other wires show 0v. Does anyone have a wiring schematic for this model lawn mower? Any tips to point me in the right direction?
No serial number given but this is what I have. See attached file.
  • TP_700_4213_01_CI_SMA_LO.pdf
