Hello, I have a 2006 Craftsman MODEL NUMBER 917.275740 27 HP 48" cut. I was mowing and the electric clutch just quit. I checked for 12V at clutch, no voltage. Went back to where the wires (red & black) come out of wiring harness and no voltage there. I can apply 12 Volts to clutch and it kicks in. I have read several posts that come close to my problem but not exactly. I was beginning to think it might be in the ignition switch but another thing that happened at the same time is the seat safety switch stopped working. Could it be the seat safety switch. Not sure how to check either. I can test for 12 volts with a meter, just not sure where to check. I have a schematic just don't know how to read it.
Thanks
Mike Skinner
OK, More info. I was suspecting my battery was not charging in addition to above problems. I wired the clutch directly to the battery with an on/off switch and mowed for about 40 minutes. Clutch quit and I killed the mower and battery was dead. Another weird thing (at least to me) the seat safety switch worked after I wired 12 volt to clutch??
Thanks Again
Mike
Thanks
Mike Skinner
Thanks Again
Mike
