wiring on a 1988 dixon ztr428
pawpaw58
does anyone have a pic or pics of how the wiring is on the solenoid on a 1988 Dixon ztr 428 . I need this real bad I have had to put 2 armatures on it because something is not right the way I have it wired. would appreaciate all the help I can get. Thanks.
EngineMan
Having the wrong wiring on the solenoid will not damage a armature, if the wiring is/has was. you have a problem with the starter.
