Does any one know where I can find a wiring harness for a 1999 Scotts mower model # S-2046
would like all the help I can Get.Thanks to all in advance
I Hope this helps, ................. (circletractor.com) their site takes a complicated navigation route , but patience will get you there ! :confused2:
From home page............. , clk Parts , ......... Scroll DOWN , ..... to ... TRACTORS, Lawn&Garden, Scotts , you should be able to handle it from there .......... :confused2:
Electrical problems are a headache .... double check CABLES , CONNECTION points Especially Battery cables , I once had a battery cable rubbing on the frame ( hard to see) but it kept discharging the battery till I found it.......... GOOD LUCK !!!
