will not turn over
keakar
replaced ignition switch , blade engagement switch and solenoid. Still nothing but I got a lot of new parts, total so far 53.00 Still will not turn over. only thing left is a safety switch. I will test them all tomorrow with a meter.
disconnecting the plug to the engine will disable all the safeties to confirm the engine and starting circuit is fine.
just keep in mind unplugging it also disconnects your engines kill wire so it cant be turned off until you plug it back in or let it run out of gas
