Will not stay running
Matt112
I have a 70 john Deere 112 and its hard to start and will run for less then a minute and die then will not start for awhile can some1 help please ?
Ifixdit
Disassemble and clean the carb and see if that helps.
Some things to check. Do you have spark, may be a coil going bad. Do you have fuel getting to the cylinders, may be a bab fuel pump or dirty carb. Do you have compression, may be a bad valve or valve adjustment. Before doing any service work, check each of these.
