Will Head Gaskets for a 25 HP Command Twin fit and work properly on a 23 HP Engine?
Joelk
If not, why not?
I know that Kohler lists a different part # for the smaller engine and that the bore size is slightly different but is everything else the correct size/shape and in the correct locations.
I prefer to use gaskets with a Fire Ring if it does not cause issues.
