Why a 500 CCA battery in Deere LX280?
chobbs1957
I have a 17HP Kawasaki in an LT180 that recommends a 160 CCA battery, but my LX280 with a18 HP Kawasaki recommends a “500 CCA Group Size 51” battery, sounds like overkill to me.
These are two used units I picked up planning to fix up and flip. These LT180 sounds like too small a battery to me for sure, and while it cranks and runs, sounds a little sluggish turning over. The LX280 does fine, as I’d expect, but that sounds like enough juice to crank a big diesel!
I plan to upgrade the LT180 to a 350 CCA for sure, a $70 battery, but am scratching my head over the LX280. It uses car type batter cables. It looks like most 500 CCA batteries go for around $165, a good bit of added expense.
Comments and thoughts welcome!
chobbs1957
I read somewhere that this model’s transmission remains engaged always, that the starter must turn the motor and transmission, thus more battery power is required. Go figure!
Tiger Small Engine
Most mowers a 300 CCA is the way to go for an average of about 3 years life on battery.
