My lawn mower had been running for about 15 when it died abruptly. There was some white smoke and the crank case breather tube was disconnected. I'm not sure if the tube had gotten caught on a low bush branch a few minutes earlier, or if it just came off of its own accord - didn't see/notice when it happened. Anyway, mower shows no sign of starting now. Any ideas? Not 100% sure what the breather tube does, as i had to look online to see what it was, so I don't know if/how it would be related to the white smoke, which seems to indicate it started to burn oil. There was also some white vapor coming out when I went to check the oil.
It is a Yard Machines by MTD mower with a 156 CC engine.
