So, the trailering one is the one that seems to be on the hitch I guess.
The other one is solid and follows the machine. Kinda like a straight shaft. I guess that would be better for not jackniffing while backing up.
You are correct. The downside is the operator is moving really fast on turns and it does not fit as well into tight spaces.
True! But, I guess even the trailering type takes room to when you back up. Is it real hard to backup with these or after a little pratice one gets good at it?
