which red fuel filter, 1/4 inch inline ?
edwardh1
e bay sells them for various prices ----small red ,for mower without fuel pump 1/4 inch inline filter 1 for $4, 10 for 4^, 20 for $5 5 for $11. and one labelled a briggs and Stratton for $5. think I may buy the oem?
Forest#2
Be sure you buy the real deal Briggs red. Costs more but worth it.
I tried the clones, every one of them eventually started leaking at the seam.
Waste of money and time.
I don't use the red pancake filters. Not fine enough filtering to prevent debris from not sticking the float valve open. I start with the white pancake and then go up in quality from there. The red filters are 150 micron and the white ones are 75 micron. I use the white ones for gravity flow and the 84001895/491035 40 micron filters for fuel pump engines or the 10 micron Kohler 24 050 13-S filters
Auto Doc's
Go with the genuine B&S, forget the cheap knockoff ones.
