where is the solenoid on husqvarna hu725awd
jhicks28630
Where is the solenoid on Husqvarna hu725awd? The push mower will run for about 5 min's and then cut off. Is it the solenoid?
If you are talking about the fuel solenoid, there is none. Next time it happens, try quickly opening the gas cap. The cap vent may be plugged causing a vacuum in the fuel tank.
