I just came across this non electric snow shovel. I know it would be pretty useless for those with a lot of the white stuff but is it worthwhile for lighter loads?
That shovel is very good. It needs only legwork and arm work. Ordinary shovel makes your body ache because you must bend a lot. You also lift the weight of the snow. This shovel, the wheel carries the weight and you don't need to bend a lot.
