hello to all I have recently brought a wheel horse b111 it was running when I brought it but needs a lot of work... my first job has been to solve the lack of spark which I have done by replacing the old points and condenser system with a newer electronic ignition coil although it is new firing well it is still not running could the timing be of?? I don't know what does the timing on these engines or will it be the carb as I adjusted it a lot before finding there was not good spark. Thanks:smile:
