Export thread
Wheel horse 416-8 not charging
#1
B
blwebster1
I just restored my wheel horse 416-8, but it is not charging. I used a volt meter on the battery. not running I got 12.3 volts dc. Running it drops down to 12.09 volts. I really don't know where to start. I have a feeling I am going to have to take everything back apart. When I took everything apart the first time I rewired the lights and by-passed the safety switches but I did nothing to the charging system. It has a amp meter, but it does not move when engine is running at any speed. Any Suggestions?
#2
M
mechanic mark
https://www.toro.com/en/parts/partdetails/?id=18789
click on parts, then gear case & ignition controls, item 12
I do not advise by-passing Safety Switches, they are there for a reason, your personal Safety & the Safety of your loved ones.
#3
B
blwebster1
where is the voltage regulator located on the 416-8?
#4
R
Here is a manual with the schematics for your unit. Sorry it is so big, but I can’t cut it apart. https://lookup3.toro.com/classes/do...789.554990546.1550861132-326972694.1543171763
