Wheel for 23 X 10.5-12 Walker MBS 27
JayTee
I managed to damage the left wheel on my Walker. I seem to be able to find a set of two new wheels and tires for over $400. Would anyone have a lead on where I can find a new, or used, 12" wheel for a Walker - 23x10.5-12 for a resonable price?
Thanks!
John
Shocking update! It looks like $441 is for a SINGLE wheel/tire combo on ProPartsDirect!!!! Also looks like just a wheel is over $300!!! That's more like auto replacement prices than a cheap, stamped wheel! I can get 5-hole wheels all day long for $50-100 for other mowers. Unless I can find a used wheel, this may get a Shade Tree Mechanic fix. :(
There are probably some aftermarket options for the wheels. Wheel diameter, wheel rim width, and bolt pattern will be needed.
My Walker is a 2014 MBS 27 HP; Serial No. 111774.
The stock number for the wheel is 2071-1; 12" rim, 4-hole- 4.25" bolt pattern. Tire is the 23x10.5-12.
Thanks for the link from Cutters; it's something like $70-80 cheaper than what Walker has.
There apparently are not a lot of after-market options. Most mowers seem to run to 5-bolt holes.
John
Well, for the time being, it's gotten a 'Farmer Repair'. Bought some 10 Gauge steel plate and plasma cut a 7" disk. It got welded to the inside/mounting surface of the wheel.
Rather than locate the bolt holes inside the roached out holes (yes, I inadvertently ran a day of mowing with lug nuts that loosened up), I went in-between so the bolts and lug nuts would help hold everything together (along with the welds).
Sooo, I'm back in business. It may not last as long as the Walker, but it will get me through the rest of this season.
John
