What's your go-to string trimmer line brand??
packardv8
Shouldn't have believed the hype:
Ballistic® Trimmer Line by Shakespeare - scientifically engineered to be more durable and last longer than residential trimmer line. Impact modifiers are embedded within the nylon to keep your line from breaking away when trimming against obstacles.
This Shakespeare the most expensive trimmer line I've ever bought and probably the worst for durability. It wears down every three feet, if it doesn't break off first.
What's your go-to these days?
jack vines
MParr
Echo, Stihl, and Rotary 0.95
Auto Doc's
A little-known trick about nylon trimmer line is to wet it with water before use. It's true and it works. I usually wet my loaded trimmer head before each use.
Auto Doc's
