Export thread
what model engine?
#1
RP54
RP54
Hi, I have a Jacobsen 21" Lawn Queen Reel mower. The mower plate says # 220-62208. I can not find any numbers on the engine itself. Can anyone tell me how/where to look for possible numbers?
Thanks! - Bob
#3
RP54
RP54
Thank you Rivets!
I already have the first one you listed for the mower itself; It's a little different model but the information is still useful. The drawings make disassembly and reassembly easier - always hate having a part left over where I have to tear it down again to install it.
The history one will be useful; I try to learn as much as I can about each mower. I think it helps with the restoring when I know a bit about the era and the background. Interesting how paint colors were often based on people's perceptions over the years.
#4
Russ2251
Russ2251
RP54:
Can post pics of what you have?
#5
RP54
RP54
RP54:
Jacobsen (Jenna) front view.jpgJacobsen (Jenna) left view.jpgJacobsen (Jenna) right view.jpgJacobsen (Jenna) carb.jpg
Sorry, I don't know how to rotate the 2 middle pics. I will be gone tomorrow to pick up a Bolens articulated mower but I'll take more pics of the engine itself when I get back.
I received several mowers at one time several weeks ago. I'm still trying to prioritize what to work with first. I'm just trying to collect info for this one right now so I'll have it on hand when I'm ready to restore it.
This Jacobsen, the Eclipses, and an F&N reel have been challenging to find anything about. The others all have B&S engines (WI, 5S, & NS), and I have all the B&S manuals, just little to nothing about the mowers themselves.
#6
R
Romore
That is a Jacobsen built engine, too many years since I have seen one so can't help with the model number.
#7
Russ2251
Russ2251
Looks like a J-321.
2½hp and is robust and bullet proof.
Probably a Tillotson carb.
Mid to late '50's is my guess.
#8
RP54
RP54
Thanks Romore & Russ,
I just got home (it's after dark) so it'll be tomorrow before I get out to take more pictures. I'll pull the air cleaner off to get more pics of the carb and I hope to pull the shroud off the engine in case they hid numbers under there. I'll post whatever I find.
I found some general info about Jacobsen engines so hopefully it will get me started. I'm sure it won't have tolerances & torques but since I'm not planning to go any deeper than cleaning the carb for now that should be fine.
#9
Russ2251
Russ2251
Some folks are under the mistaken idea that they were manufactured by Tecumseh.
They were not.
IMHO they are one of the most underrated 2 cycle engines out there.
#10
RP54
RP54
They were not.
I've heard that too. The more I read about Jacobsen the more impressed I become; This Jacobsen was one of the reel mowers I've wanted for a while.
#11
J
jp1961
Hello,
If you ever remove the rod cap, do it over a plastic tray, as the needle bearings will fall out and go everywhere.
Been there, done that,,,LOL.
Regards
Jeff
#12
RP54
RP54
Hello,
Regards
Jeff
Thanks Jeff!
#13
C
Cottenerik
View attachment 46063View attachment 46064View attachment 46065View attachment 46066
I recently(this week) picked up a beautiful Jacobsen Lawn Queen and I would really like to restore her. She is nearly identical to the one you have pictured.
Do you know where I can look up the serial number and find repair manuals?
Thank you
#14
U
uptown
whats the serial #? ill look it up for you in my book
#15
U
uptown
Serial number says it's a 1950 20" lawn queen. Looks to me like the early j-100 Jacobsen engine. 1.8 hp
#16
U
uptown
Second thinking myself. 2inch bore 1.5stroke on a 1950 lawn queen would have to be a j-125 engine. Should be a mt-58 or a mt-77a tillosen carb on it
