What model do I own
juffman
I became the new to me owner of this nice simplicity yesterday morning. I nor the previous owner know the model number or the year. So I was hoping someone here could help me out. Thanks in advance.
juffman
That's all I have the rest of the tag has a huge chunk out of it. I cannot find a model number it has a 16hp Briggs but I am curious if the motor hasn't been switched out at some point in it's life. Is there any other way to tell the model number. I googled it and it came up with 7013s but it looked slightly different
mechanic mark
That is your model number, 1690232. Simplicity tractor model numbers are seven digits. When you get ready to order parts just google Simplicity Tractor parts. Older model tractor parts have sometimes been discontinued, therefore you may have to search for used parts.
And yes the engine may have been changed out for an upgrade, more horsepower. Can you find numbers on engine?
https://www.google.com/webhp?source...&espv=2&ie=UTF-8#q=simplicity tractor 1690232
juffman
no numbers on the engine. only thing i can see on it is it appears to be a 16 horse briggs. thanks for the heads up on the model as i need some parts this one is not recharging the battery.
