I was mowing the lawn with a 22" Self Propelled Brute Briggs and Stratton. and it just turned off. I put more gas, but it wouldn't turn on anymore.
I don't know much about fixing mowers, but I opened it up and removed the ignition coil because a friend I talked to told me that could be it. However, I don't want to buy a new ignition coil if that's not the problem.
Then, I saw that the pipe under it was cracked. The picture is attached. Does this crack mean anything and could it be the reason the mower doesnt turn on?
Thanks
Thanks
