Skippydiesel
- Nov 29, 2020
- 512
Its simple -
- For most plants (not all) the relationships between the aerial (above ground) foliage, is directly proportional to the subterranean (roots).
- Scalp (cut your foliage down to near dirt) & you reduce the root system volume & depth of (soil) penetration.
- Given your clear understanding of plant physiology, you probably unaware that the roots deliver water & nutrients to the aerial (above ground bit that you can see ie lawn).
- Reduce the root system, when there is plenty of soil moisture and nutrients (fertilizer) you will probably get away with it. Your sward will be stressed but will live.
- Do the same in dry times and you wont be so lucky.
- Also - the leaf (blade of grass) is where the plant generates the energy to live - no leaf, no plant.
- Humans, in their drive for their idea of aesthetic perfection (the fashionable look) all to often ignore the needs of the plant.
