What compression on 15.5 HP OHV engine model 282H07
wilburn cox
Does anyone know what the compression should be on a Briggs 15.5 OHV should be? Model # of engine is 282 H07. Type # 0196E1. Code # 058217ZD..I had to replace the cam because the automatic release mechanism was broken. Removed the head and cleaned all carbon from head and top of piston.
Briggs, as you know, does not post any compression specs. Any help will be appreciated.
Thanks in advance,
Red Cox
