My mower randomly dies when I am mowing-already replaced fuel filter, new carb, spark plug and so forth last fall. Did not help. My next guess is the coil. I see from the schematic (I am looking at boats.net but schematics same on all sites-sorry could not get it to copy over) there are 3 coils, two under the flywheel (7 and 15) and one on outside of flywheel (3). Since the outside one is the one that provides the spark plug spark, I intend to replace that one. This is my question. There are two coil assemblies part numbers on item #3. One is 30500-zf5-l31 part # 4789475 listed as SUP: Coil Assy, and the other is 30500-ZF5-L32 part # 7088271 listed as PRI: Coil Assy. It seems last time I had this thing apart, I only remember one coil on the outside of the flywheel, which would be the one with the spark plug wire. Can anyone tell me what the difference is between L31 and L32. Are there really two coils on the outside of the flywheel? If so, which one should I be replacing? What am I missing in this picture? While I am at it, what is the gap between coil and flywheel?
