What carb do I have? Need a rebuild kit
neverquit
Hi: Have a weedeater featherlite I bought at a garage sale several years ago. Works ok, just getting harder and harder to start, so figured I'd rebuild the carburetor. Well, trying to find which carb it is, is almost impossible....There's soooo many models, so can someone help me with the model and/or the rebuild kit. Speaking of the rebuild kit, I've seen there's either a rebuild kit or a gasket replacement kit. Wouldn't the gasket replacement kit be the way to go? I don't understand the difference, if you're going to overhaul the carb, replace all the gaskets.
Ok, here's the data that's on the weedeater:
SKU 952711334
Family 3PWE8 0183TZ
Serial # 03339N?3189-4 ( 19:02 ) ? = can't read the number
Mod Featherlite 711334
18 cc
If one of you can help ID the carb and tell me which one it is I would really appreciate it!
Thanks
Lloyd
If I remember correctly that unit uses that stupid choke system on the back.
Use this Carburetor For Homelite 308054013. Just remove the choke lever and you will be ok.
Also if you keep the choke it will work as the auto choke. This is you put it on ckoke and when you press the gas it automatically go off choke.
