i've got a 2000 white gt 2550 with 50 inch deck and a briggs 25hp twin.Last year the transmission beltbroke which i have replaced once before with no problems.This time after putting it back together it wont start and im fairly certain it was re installed properly. if i remove the pto it will want to start.
Also since ive owned the mower it can be hard to start from time to time and if i put my battery booster on it,it will start fine.I know the battery is fine and has been replaced and i keep it on trickle charge when not it use for extended time period
