I have a starter problem with my Kubota G1800 lawn mower. Have tested starter solenoid & starter from battery. Both run fine. When I turn on the key I get nothing not eeven a click.
Any ideas?
Too most common issues in your case would be the safety switch on the clutch/brake pedal, and the deck engagement safety switch. if electric PTO then the safety switch and pto switch are one and the same.
