Hey guys, I'm having a strange issue on a Bolens G808H, where the brakes do not work at all with the engine running. With the engine off, the brakes work fine - I cannot push it with the brake pedal depressed.
I pulled the little disc brake/caliper assy off the rear axle and inspected the pads and mechanical function (springs, pins, rod) and all seemed to be fine.
I did change the drive belts a few months back, but it has worked alright since, up until recently. I am not familiar with the transmissions/transaxle on these, so I am not sure if this is belt tension related? Or more transaxle (internal) related?
Any guidance on this would be greatly appreciated!! Thank you
