Export thread
Weedeater PE550 2 cycle edger will not start..need some expert advice please
#1
S
shelby5041
hi
i have to say im struggling with this one..i have been tinkering with this weedeater PE550 gas edger for a couple weeks now...it started ok couple years ago but now it will not start now.
i will give you some condensed info of what i have done so it may help you direct me to next step to get this thing running or trash it
during my process of troubleshooting it this year....the primer bulb and gas lines fell apart...so i have replaced those with new parts.
i do get spark....and .if i put some fuel in the spark plug hole it tries to start after about 10-15 pulls....it struggles but eventually it will start for a fraction of a second...
i took carb 100% apart and cleaned with carb cleaner.....i then reassembled and still no start
i can push the primer 100 times and when i take spark plug out i see no sign of fuel....is this normal?
would a carb rebuild kit fix this?....carb needs replacing?...or could i have another issue why it wont start
carburetor is a walbro wt-630 i believe carb with primer bulb built in....pretty common on many 2 cycle yard products
any help would be appreciated...
thank you
#2
S
shelby5041
would like to add
when i did take carb apart i did not see anything unusual..it was pretty clean..the screens were clean..no evidence of anything visually gunky
i sprayed carb cleaner in all the holes i could see per online tutorials
and like i said it will not even try to start at all without putting fuel in spark plug hole
this tells me it should be a carb issue but......i figured cleaning carb should have resolved this issue but it didnt
#3
The problem with the primer bulb carbs is there is check valves inside to make them work properly. If those check valves stick open it won't prime, and most of the time it won't start. If they stick shut you don't get any fuel into the engine. Most of the time the cost of the replacement carb is cheap enough to just replace it.
#4
S
shelby5041
and fyi primer bulb fills up with fuel fine so its not a fuel filter ...fuel delivery to bulb issue
#5
S
shelby5041
a replacement carb is about $27.00
would a carb rebuild kit help me with this no fuel issue?
but yes i can prime 50 times and fuel just goes into bulb and excess back into tank
it seems none is going into combustion chamber at all
#6
BlazNT
BlazNT
OK so you have an air purge bulb. IT removes air from the system. It does not prime the engine. If it did then you would flood the engine every time you pushed the bulb.
#7
S
shelby5041
Ok...guess I'm confused
How does fuel get into,combustion chamber then.....I have no fuel in chamber at all....
#8
S
shelby5041
My lawn mower primer bulb shoots fuel into carb....I guess not same as 2 cycle engines primer bulb...
Why would I have no fuel issue....I have taken carb apart and cleaned 100%....
Still no fuel in combustion chamber
#9
primerbulb120
primerbulb120
Your lawn mower carb and edger carb work differently. The mower just has a primer bulb which shoots fuel into the carb throat. The edger has both a primer bulb and a choke. The primer bulb simply removes air from the fuel lines for an easier start. The choke is used to enrich the fuel mixture. You can start a 2 cycle without the primer bulb if you pull it a few times extra (fuel pump will purge air from the lines.) You can't start a 2 cycle without choke unless you give it a shot of starting fluid.
#10
S
shelby5041
Ok thank you...why do people say the primer bulb floods 2 cycle engine so?
And what would cause no fuel issue in a 2 cycle carb..walbro
#11
If the check valve in the main jet/nozzle sticks shut fuel cannot get through the jet to enter the venturi of the carb to be drawn into the engine. Common problem with taking apart the carbs, and the use of carb cleaner tends to make the rubber flap in the check valve swell.
If the check valve sticks shut not fuel gets into the engine. If the check valve sticks open the primer sucks air back through the open check valve in the main nozzle preventing priming.
#12
S
shelby5041
would anyone know if a no fuel issue could be resolved by rebuilding carburetor via carb rebuold kit
or do i need to replace the carburetor
i get fuel to primer bulb but none going to combustion chamber
#13
S
shelby5041
sorry didnt see your previous reply before i sent last message...
#14
T
Telesis
I would recommend trying a gasket kit(after you've checked the compression as noted in the next paragraph). I always replace when I've taken the time to pull a carb off a piece of equipment. The kits are available for around 10 bucks so for me, it's a no-brainer. The metering diaphragm and the fuel pump diaphragm are the parts that should be replaced(along with their respective gaskets). Pay attention to which side of each diaphragm the gasket goes. (metering side: carb body>gasket>diaphragm pump side: carb body>pump diaphragm>gasket ) I wouldn't recommend the full rebuild kit, just the gasket kit.
Check compression. Rule of thumb is 90+ psi for a 2 cycle. Can you pull off the muffler and peek into cylinder to see if a) the passage is clogged up with carbon deposits and b) if the cylinder walls are scored or not. Either of these conditions leads to minimal suction of fuel into the cylinder during intake. (same with a clogged muffler or spark screen) These would be good things to check before plunking money down for a new carb or a gasket kit. If you find poor compression due to a scored cylinder, it's usually time to "declare victory and move on!"
There are certainly more checks such as air leaks on the carb/intake side of things but you need to make sure you don't have a 'door stop' first.
If you don't have a compression tester, you can get an inexpensive one for $20 or so. Worth the investment if you want to keep tinkering with small engines.
Good luck
#15
S
shelby5041
compression not an issue ...it tries to start if i pour fuel in plug hole
hi i dont know if you can help me or not but im frustrated with this pe550 edger
..am struggling bad ....have spent days on this weedeater edger...edger will not start
if i pour some fuel in spark plug hole the edger tries to start.....but if i dont do that the edger will ot try to start
the primer bulb functions as its suppose to.....i tried to start it with and without using primer bulb...it will not try to start at all.....
i have taken the carb completeyl apart and cleaned 5 times.....its clean.....nothing looks visually bad or clogged up.....
the only thing now is that the gasket from carb to manifold is messed up a bit near 1 screw hole area......but this happened later after taking apart so many times the gsket tore a bit at screw hole
this wouldnt have an effect regarding starting would it?...it didnt start when this gasket was perfect either
what should i do?
would a carb rebuild kit fix this or do i need a new carb or toss in trash
#16
S
shelby5041
and fyi removing carb from this item is simple but removing anyhting else is virtually impossible and can not be done....poor user friendly design to say the least
cant remove muffler cant get to it....
#17
S
shelby5041
pe550 gas edger new gaskets new carb.... still no fuel issue and wont try to start will only start if pour gas in plug hole any ideas?
#18
S
shelby5041
update:
found issue
it wasnt carb issue
took entire engine apart and found out the problem....and now it starts and runs...installed old carb back and works fine now
2 months of headaches....craaazzzzyy
but i did learn something now...and can prob troubleshoot 2 cycle engines way better now then prior to this fiasco
thanks for anyone who may have contributed...any and alo info helps even if its not correct..
#19
G
gttman
So what was the issue. It is driving me crazy too.
#20
T
TerraForte
YES
Check valves?? In a 20cc engine carb?
Wuuuuut?
exactly what it's supposed to do.... :eek:
Finally someone says it...
BY PULLING AIR THROUGH THE CARBURETOR
Not really. All small engine carburetors are remarkably similar.
All of them have a choke mechanism. On the cheaper lawn mowers, the choke is automatic because people who buy $150 lawn mowers can't be trusted to use a choke properly. On higher end and commercial mowers, there is a dedicated choke mechanism.
Additionally, you can start a small engine un-choked when it's cold, but it would take many pulls. Not worth it. The choke was invented to make starting MUCH easier.
I'm sorry, but this thread was such a mess to read.
I can't believe not once did anyone tell him the proper troubleshooting steps or even suggest using starting fluid. Wow.
Doesn't start?
Check ignition - on/off switch; check for spark at plug boot
Has spark?
Rule out fuel issues by artificially supplying the engine via starting fluid
Still won't run?
Check for any possible airflow obstructions - clogged/blocked air filter, intake, or possibly exhaust.
STILL won't run?
Likely blown compression. Remove spark plug and look into cylinder to check for scoring
#21
G
gttman
OK read all of that. I replaced edger with a new carburetor and new fuel tank with new lines still does not start. I gives me one loll burp and then nothing. I have had carburetor off and on many times gaskets getting a little rough. There is no leaking of fuel anywhere. New plug. Sparks fine. What next. Trash it?
#22
G
gttman
Also using premix 40:1 non ethanol fuel.
