Export thread
Weed Wackers??
#1
W
Wing Nut
Is weed wackers OK to talk about here? I have a old one needs replaced. 31cc engine. Can't seem to find one bigger than 28-29cc. How much power am I losing? Tried a Weed Eater brand before, 25cc and wasn't happy at all. Live in country and get some tall stuff. Any advice? Thanks!!!
#2
R
Take a look at Echo, just bought a new one last year and if I try to use at full throttle I rip up everything. Depending on model, you can even attach a brush saw for the really big weeds.
#3
Ric
Ric
Try Stihl Trimmers if you're looking for larger engine size and more power. Echo's largest Trimmer engine is the SRM 280 @28.1cc
FS 100 RX 31.4 cc (1.9 cu. in.)
FS 110 R 31.4 cc (1.9 cu. in.)
FS 110 31.4 cc (1.9 cu. in.)
FS 130 R 36.3 cc (2.2 cu. in.)
FS 250 R 40.2 cc (2.45 cu. in.)
FS 310 36.3 cc (2.2 cu. in.)
#4
C
cjdave
I just bought a Craftsman 31cc on sale 109.00.
#5
R
We sell both Echo and Stihl and even though Stihl has a larger engine the Echo produces more torque.
#6
W
Wing Nut
Hows it working for you? Like? Prefer to stay away from Sears Kenmore. Was it on sale at K mart?
#7
W
Wing Nut
What Echo model do you recommend? Prices?
#8
U
unkledude
Wing nut, There's a very good article @ popular mechanics about they're recommendations. I know they can be bias but it'll give you some idea at least.
My 2cents:
#9
N
noma
HI Alll
I have a craftsman 32 cc bushwhacker trimmer with attachment and it has pretty good power i live on a acreage and we get some tall grass to and works ok. Last year i left some old gas in it over the winter and had to replace the carburettor:licking: but now works very good.Can put a blade to trim small trees off that works ok just don't try to cut very big trees off it will smoke you saw blade.:licking:
#10
N
NEgravely
Take a look at a home owners RedMax trimmer. I currently have a Stihl but after buying a RedMax blower a RedMax trimmer will be the next trimmer I buy. The blower is light, powerful and very easy to start. I would expect the same from the trimmer. A friend of mine swears by his RedMax trimmer and loves the ease of respooling. Good luck with your choice.
#11
talley2191
talley2191
I haven't kept up with weed eaters but I've been using a Shindiawa (I have no idea if that's spelled right) for 8 years and that is after it was removed from commercial service where it was for 6 years. I haven't even replaced the spark plug.
#12
N
Natureboy
I agree. Bought an Echo SRM2110 many years ago, still going strong.:thumbsup:
#13
J
jerye
Maybe with your 25cc with the right kind of blade you could get away can do all the work you need without buying a new machine as Ken Morrison reviewed here:Ken Morrison's Power View Article on how the Airecut doesn't need so much power for weed whacking.
#14
M
motoman
I only have experience with one, but what a great tool, I bought Ryobi 729 iin 2000 . Bump head uses .090" string. This tool is one of the best all time tools I have had. It has cut acres of tall wet grass and ploughed tons of earth while edging/ weeding-yes abused to weed down to roots of unwanted plants. The two bumpheads I use are so worn you can hardly read the instructions on the plastic.
I took it apart 2 years ago and lubed the pinion gear. It has never failed to start. Use Poulan two stroke synthetic oil. Keep the little plastic foam air cleaner washed and oiled. Use a platinum plug.
Over the years I have read a lot of negatives about the Ryobis. Don't know if I got a ringer or not, but if it failed tomorrow I would keep on praising it. I do not give out accolades as a rule.
#15
M
motoman
CORRECTION: Ryobi model is 790R 31 cc with optional blade attachment. Sorry .
