mn shutterbug
- Jun 18, 2017
- 1
- 1
I started the weed eater yesterday and gas started dripping down. I found one of the fuel lines had split. I found some oxygen hose that I thought would work and although the proper size, it was too soft and would continue leaking where it connected. I just need to get the proper tubing. However, while messing with it I noticed what appears to be a gasket sticking out in one area, as shown in the photo behind the pull cord handle. This doesn't look quite right. It's tight and can't possible move so how did it get in this position? We went from 3 small engine shops locally to just 2 and the one no longer works on weed eaters and the other is just a 1 man shop inside a Hardware Hank and I was told it would be a 6 week wait. By then it will be just about time to get the snow blower ready. Thanks.
