1 Lucky Texan
- Feb 26, 2013
- 575
Re: Warning ! Serious error in Greenworks 20" Dual Blade Mower Maintenance Instructio
OK, indeed the error is in the manual (at least 2 of the pdfs I looked at on-line, my original is long gone)
but, the construction is as I outlined in post #6 - also, my original blades as well as a replacement pair both have correct instructions stamped on them - as long as you KNOW, blade 1 is the forward-most blade. (though, the whole lock/unlock iconography is kinda odd)
I just sharpened and installed my back-up pair, with new plastic holders, and the forward motor's shaft is 'normal' righty-tighty.
but, page 25 of this pdf is wrong(as outlined in post #4 by pumper54);
https://www.manualslib.com/download/640852/Greenworks-25302.html
