Engine Wants to Stall
RLMontgomery
Once I engage the mower and start mowing, the engine wants to stall out or just quit running. When I disengage, it appears to run fine. This is after I had the mower serviced. Any thoughts on the issue.
BlazNT
My thought is whoever serviced it needs to fix it. Either too much air or not enough fuel. Broken carb gasket for air problem and dirty carb or obstruction in fuel delivery system.
