Wandering Scag Turf Tiger
Knots
Has anyone had a problem keeping their Turf Tiger in a straight line? It does not slowly drift one way or the other but moves erratically away from your intended line.
Steering shocks have been replaced with new HD units.
Would front wheel preload have any bearing on this?
Any thoughts would be appreciated.
Numbers:
STT61A-27CH
9380240
Thank you,
Knots
MParr
Were you having this problem before installing the new steering shocks?
New steering shocks can be a little stiff and sometimes you don’t realize that you are giving a little more input. This can cause you to push a little harder. Then you over correct with the other lever. Sort of a zig zag effect.
