Walker Mower won't go forward or reverse
Vman
I have a 2008 walker mb 18 and my son was using it. The drive belt came off (which it has before) so I put it back on and it would not move. I purchased a new belt and put it on but the same the same thing, it won't move;however, it does move seem like it's trying to move a little more with the new belt. Mower starts fine and the deck will engage and run fine. Any suggestions to what it could be would be greatly appreciated!
BlazNT
Purging Air from Hydraulics
1. Raise rear wheels off ground. Brace with jack stands.
2. Put bypass valves so it freewheels.
3. Get on mower start it and release the brake.
4. Push drive lever full forward for 10 seconds the full reverse for 10 sec. Do this 10 times for forward and 10 times for reverse alternating between each.
5. Return levers to the parked position and set brake. Turn off the mower. Move bypass valve bake to normal operation.
6. Get back on the mower and start it. Do step #4 again.
7. Return levers to the parked position and set brake. Turn off the mower.
8. Return mower to ground.
9. Test for proper working. If not repeat.
10. Check oil level and fill.
